Red Lion Kadet G304K200 replacement
pingac
Oct 2021
Prague
Good day everyone,
I need help with the problem.
The HMI Red Lion Kadet G304K200 broke in our company and since it is no longer manufactured, we chose Maple Systems HMI5043L as a full replacement. Is it possible to use the original UI created in Crimson 3.0 (.cd3), or to compile it for EBPro, or is it necessary to create a completely new UI directly in EBPro?
Thank you for answer.
I'm not familiar with the Maple product, but I doubt that it's possible to import a program file from another manufacturer.
Just FYI, Red Lion released the CR1000/3000 series as a replacement for the Kadet. Crimson 3.1 can import the Kadet program and translate it for use with the CR. (Part # for 4" model is CR1000-04000-00210)
If you had gone for another Redlion as a replacement you would have saved yourself a lot of effort. You will have to recreate the Redlion program screen by screen in the Maple system HMI. You can download the Redlion Crimson software:
https://www.redlion.net/red-lion-software/crimson/crimson-30
If you have a back up copy you can deconstruct it part by part and recreate it on the Maple HMI. If your time is more important than the price of a new new HMI, get a Redlion one and go for the easy life.
I am in the process of migrating a Quickpanel Jr screen that has a few dead pixels resulting in hard to read numbers. The current PLC is a old GE...
2,270
Has anyone experienced any retentive memory loss on recent Red Lion Kadet screens (G307 in particular)? The equipment in question has a G307K200...
2,110
How do I address a B3 bit from Allen Bradley to a tag on Crimson 3? They have options listed as B 003:0000 and Allen Bradly has it named B3:0/0
2,389
I have a Red Lion G307 Kadet. Turns out I have a ghosting issue on the screen. It appears to be temperature related. When the device is cold...
5,549
Is there a procedure available to align the touchscreen of a G308K? On the unit I have the touch area appears to be consistently above and to the...
3,289
