RedLion G3 and Barcode Reader
I made a demo once for an Ethernet Barcode scanner to a data station plus. It sent an ascii string over ethernet to the module. A little bit of scripting to parse the string and move values to the corresponding tags (since it was sending quality, X, and Y data as well).
Just set up a Raw TCP/IP on the ethernet communications, and called my program on update.
We've got a big project gaining traction that is going to consist of 30+ barcode scanners that will scan barcodes on mill rolls of film, and then parse the barcode into a "recipe" # and a unique serial number.
At this point we are thinking of using a Crimson GL306 as the interface between the scanner (haven't settled on a model yet) and our L61 PLC's.
A serial scanner makes things easy. 10 minutes of parsing data and you are done. I might even have a few examples.
I did 1 TCP it wasn't too bad.
There won't be much to parse. The barcode will be a six digit part number. From there it will load the recipe that matches the part number. That part is already being done - the girls are just asking to input the part number by barcode instead of entering it by hand. Check your PMs Jeff.
Hi again all. First off let me say how valuable all your ideas and help is. Even what you thonk is a small answer has helped me emensly. Ok I...
2,178
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
147
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
180
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
239
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
669
