Redlion G3 to ControlLogix - !@#@#!!
TConnolly
Apr 2005
Salt Lake City
6,152
OK, I really like these units but there are a couple of things I'm having difficulty with.
1)Once I create a PLC tag I can't seem to delete it. o_O
2)The only tags I seem to be able to get to are controller scoped single element tags, can't access and .elements in the tag, eg Timer.ACC, or UDT elements or array elements, I have to make an alias to them.
Is it something I'm missing and/or what are the workarounds?
EDIT: OK, nevermind on #2. When I set protocol1 under Ethernet to Native Tags via L5K file I was able to get to all of the tags. Before I just had it set to Native Tags and couldn't access sub elements. Not sure if I was doing something wrong or if I have to select the "via L5K" option.
Hello,
What is the format for the tag? For example:
Door_Open -- a bool in global scope - global assumed with no program prefix.
First:Door_Open -- a bool Door_Open in program First.
<program>:<tag name>.<element>
Just a guess.
Good luck,
Mark
http://www.peakhmi.com/
A few examples:
I can access these and similar tags:
Controller: Piston[0].TargetPos
Controller: Piston[1].Velocity
I can't access these locally scoped tags (and others)
FlowMetering: Tool[0].FlowRate
Pressure_Control: Pressure_PIDE.PV
Locally scoped tags do not appear to import and don't show up in the tag browser.
> - The spec that we were given says that only Controller tags can be accessed via the protocol.
I am not sure what protocol he is referring to but, I do know via Ethernet/IP it is possible to read and write program scoped tags.
PeakHMI can do it.
Good luck,
Mark
Shhhhhhhhhhhhh you didn't hear this from me!!! I heard from a little Red bird that they are working on this and have reversed some systems to make things happen.
Is it possible to Map a Logix Dword or a Word bit as a Tag in Redlion G3? Basically I want to have a DINT Tag from Logix as a Single (not an...
1,838
Hello all. Looking for some help & advice on part of a struggling project I've been roped into, the project has several process analysers...
4,695
Since the most recent Crimson update of C32-Gold-1016 I seem to have lost the ability to move files on the SD card. I run a background program...
39
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
155
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
192
