REDLION Read Controllogix Bit of word/dword. How?
skyfox
Nov 2006
CA
279
Is it possible to Map a Logix Dword or a Word bit as a Tag in Redlion G3?
Basically I want to have a DINT Tag from Logix as a Single (not an array of DINT's), Tag in Redlion. Then Afterwards, map another HMI tag(s) to refrence a bit(s) in that DWORD. Is this possible?
Scared of using Logix Bit arrays in Redlion G3. Somehow Mapped bits seems to get changed or De-refrenced with subsequent HMI uploads after modifying the HMI program. I am carefull about generating a new L5K file each and every time I do PLC changes, and then loading that in to CRIMSON before I do any HMI updates. Eventhough I have not done any changes to the structure of the previously uploaded and mapped bit array Tags, tag refrencing seems gets changed sometimes. Happened to me three or four times already. Totally scared of sending HMI updates to the field when this happens this often.
I am importing the L5K from COMM's and am using the Latest CRIMSON 3 version. Any Ideas as to what is causing this?
Hello There, is there any possibilities to read Redlion Kadet Series HMI internal string tags over Modbus TCP/IP. we read other tags using...
2,599
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
171
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
222
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
