How to Read Redlion HMI internal String Tags over ModbusTCP/IP
amit22
Jun 2008
gujarat
64
Hello There,
is there any possibilities to read Redlion Kadet Series HMI internal string tags over Modbus TCP/IP. we read other tags using holding registers address starting fro 40000 but for the string tags its nit working.
can anybody help with sample program?
Hello rguimond.
I am not getting you. what do you mean by extract program? will give Modbus address for the internal string tags of the HMI?
Sorry, I misunderstood you. I think you want to read from the HMI, just as you would read from a native modbus device. In this caase, you cant't. However, you can probably write the values to the device you want to read them from. You have to set up a communication block for this. <
You can raed from a redlion over modbustcp. you need to install the modbustcp slave driver, then you can read from the unit
Hello rguimond,
thanks for the response here. can I have small example for this? as we never work with communication block.
thanks in advance
hello Geoff c,
thanks for the details. can you send me configuration screen shot or example if possible.
Regards
and Thanks in Advance.
Is it possible to Map a Logix Dword or a Word bit as a Tag in Redlion G3? Basically I want to have a DINT Tag from Logix as a Single (not an...
1,833
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
180
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
139
Hi everyone i have a customer, who wants to show an alarm on the machine, if the I/O forces are enabled and set, on at ControlLogix L81E with...
271
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
109
