TConnolly
OK, I really like these units but there are a couple of things I'm having difficulty with.
1)Once I create a PLC tag I can't seem to delete it.
2)The only tags I seem to be able to get to are controller scoped single element tags, can't access and .elements in the tag, eg Timer.ACC, or UDT elements or array elements, I have to make an alias to them.
Is it something I'm missing and/or what are the workarounds?
EDIT: OK, nevermind on #2. When I set protocol1 under Ethernet to Native Tags via L5K file I was able to get to all of the tags. Before I just had it set to Native Tags and couldn't access sub elements. Not sure if I was doing something wrong or if I have to select the "via L5K" option.
