Redlion G3 web server security
stuman
Feb 2008
Benalla
37
Is there a way to force a minimum time between login attempts on a redlion g3, specifically the web server and remote access?
I would like to minimise the potential for a password attack/brute force attack, to crack the security on my application.
Any other suggestions are more than welcome.
Stu
I don't know the answer to that question, but I have seen customer's logs that have tallied hours of hacker automated attemps to get in only to be denied.
Joe_WaZoo
Nope. Not a bad idea, though. What sort of delay are you looking for? A short one or one that increases with each attempt could be added without any need for configuration; a longer fixed one would need to be optional.
An adjustabe one ? Tag related ?
Say a 5 second delay that increases with each unsuccessful login attempt. When you say without the need for a configuration, do you mean that this functionalty could be included in the next release of Crimson2? because that would be fantastic!!
Stu
Would this change also apply to DSP, we have ours on a 'closed' network at the moment, but as we develop the application and add more we may end up having them connected to our existing network infrastructure, in which case security will be an issue, and I would like something similar.
I was wondering if anyone has used a Allen Bradley Control Logix Processor with the 1756-EWEB communication card instead of a standard Ethernet...
2,310
Hi all I just upgraded our G306 to a bigger G310 display. The G310 just will not serve a web page to the Internet. I can see it on the LAN...
2,234
Hey guys, The TL;DR is the last two paragraphs with a web link for you to try yourself. If you don't have anything better to do, look at the...
17,057
I'm using the PTV as a web server. Very neat stuff. does not play nice with FireFox. Works well with IE and also with iPad. Any ideas on how...
1,597
When writing a User Defined action with Complex Code, can I call for a GoToPage "Popup"? I have a machine function that I want to confirm only...
21
