Redlion G3 with Micrologix 1200 plc
amit22
Jun 2008
gujarat
64
Does anybody have G3 series hmi and Micrologix 1200 communication diagram with cable details.
and if anybody have the sample program then please attach it.
i know...but little bit confused..i tried so many times not done..see i have micrologix1200 having round pin RS232 9 pin connector..then in the redlion we have RS485 and RS232 ports having RJ45 and RJ12 connectors..
they have given diagram for RJ45 to RJ45,..and so many..
now if i will use the NETAIC connector from the AB then it helps or not?
and i want sample program for the same as i have some questations in the configuration the communication.
hope now you can understand.
thanks in advance....
amit22,
We don't offer a cable to plug directly into the round mini din connection on the micrologix. We do offer a cable (cblgen01) which would connect to your micrologix programming cable.
Jeremy
Hello, Anybody having sample program for the Micrologix 1200 and Redlion HMI using PM02 cable of Allen Bradley. Requesting you to share for the...
2,479
Hi, I am using a Micrologix 1400 for a project, and we were supposed to use a 4.3in PanelView HMI. By means of delivery times, that won't be...
981
Have a question i hope someone on here could possibly assist with. I have spoke to Red Lion and they tell me you can assess the G308 using the web...
3,181
How do I access bits 16-31 of a 1762-IQ32T card in crimson? Bits 1-15 are easy, I use "I001:0000" and select bits 0 through 15. Unfortunately...
1,250
I am using a Data Station Plus with Crimson 3.0 and connecting to a AB Micrologix 1400 PLC via Ethernet. The issue I am having happens randomly...
4,175
