Richard Webb
Hi, new to the forum, and desperate. I am trying to connect a RedLion G308 via ethernet to a Logix 5562 PLC. I am connected via a switch directly to the ethernet module in slot 4. The CPU is in slot 0. This is the first time I am using RedLion so a bit in the dark at the moment. I will insert a few images of my setup. Any help would be great. Also, I have seen in other threads, there is a way to see if you are connected to the PLC, that would be great as well.
