Redlion talking to an Omron CJ2M Fins
Ok So I got Redlion
PLC Network 192.168.0.10
HMI Network 192.168.0.20
RedLion 192.168.0.25
In Red Lion
Destination Network: 1
Destination Node: 10
Destination Unit: 0
Source Network: 1
Source Node: 25
Source Unit: 0
Under Protocol Option:
UDP Port 9600
Is that all? sorry but my plc is 1 hour away and I will lose network going there thanks again for the help ATU.
Never used it. I can't help you there.
I use CX Integrator and setup the router table through that.
Just call Omron Support they can walk you through it. That's what I did. They are real helpful and it doesn't cost anything, unlike some others.
True, they don't seem to nickel and dime you on everything ;) Thanks again for all the help.
Hey I got it working (Oh yeah yeah)
The routing table was set for the SIOU to match the unit number (Rotrary Switch on the Omron PLC)
And the Network Number is the number on the right when inserting it under the table tab. When making a Routing Table
Routing Table:
http://www.youtube.com/watch?v=kDYP-bUMzEg
So my understanding of the routing table is basically making an Ethernet Connection (Not Ethernet/IP two different things) to a device that has not EDS File
Here's my scenario: Using a standalone NX-SL3300 with a NX-EIC ethernet IP adapter. I figured I could potentially use the Ethernet/IP Slave...
1,604
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
126
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
228
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
662
