Redlion Webserver
john.morley
Oct 2011
Australia
I have a a Red Lion G12 Graphite HMI connected to a L32E compactlogix. The System has a 3G mobile modem to enable remote login. The mobile reception is in the area strong (-50db). I have set up the web server, I can connect and it displays the screens OK but the response is very slow. I have other brands of HMI that work well over the same connection. Has anyone had good experience with the redlion webserver over a mobile 3G data connection?
I have had "slowness" more than once.
At one point, there was a rogue router on the network as the root cause. It was spewing packets in circles and cluttering up the whole system.
Another time, I seemed to have an issue with IE. Chrome ran better. And it seemed that if I left the remote connection active long enough, the performance improved.
None of these suggestions are scientific or really specific and there are probably other things I am forgetting at the moment.
And call Red Lion Tech support if the problem makes the system unusable. I bet that they can offer ideas.
Welcome to the Forum!
I have a customer that uses a very similar setup all over Australia and it works very well. I mean, it's not lightning fast, but then these systems are out in some very remote places and it's still usable.
Goodevening all... I have a Redlion PTV and Graphite with built in webserver... I can create the simple default.htm page... drag in tags to...
1,911
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
225
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
658
