Reducing Program Memory usage in S7200
sanket_shete
Jun 2005
Mumbai
Hello all,
Im working on Purified water s/m & distribution plant. I m using S7200 plc alongwith Beijers Eterminals for various plants.
S7200 plc CPU224 has 8kb program memory & i almost utilised it fully for my application, now i have to introduce few additional interlocks in it.
Some of my friends told me to use subroutine for repeated logic,
this will save memory, but i found out writing sub routine & calling it no. of times uses same amt of memory in my program.(n)
Plz guide me
:confused:
Thanx to all
with regards
Sanket
Subroutines (SBR) in S7-200 can be used in two ways:
- not parameterised (this will not save any program memory)
- parameterised (this sure can save program memory)
This is how you can make a parameterised Subroutine:
1)First make a subroutine (SBR) with local variables (#naam)
You can use IN, IN_OUT, OUT and TEMP Variable types
2)Then you can call your subroutine several times in your user program.
Each time with other PLC addresses
PS.: This is similar to S7-300 (“normal” FC’s and parameterised FC’s)
Good luck
Hi Sanket
There is a method to increase the amount of memory available to your program from 8192 bytes to 12288 bytes, though you loose the Run Mode Edit facility. You need up to date versions of the PLC and I think version 4 of MicroWIN. Can't try this myself as I am still on MicroWIN 3.2, but as described in the manual you go to View / System Block, Select Increase Memory and then download the updated program to the PLC. Let me know if it works, it might entice me to upgrade MicroWIN.
Bryan
I am deciding on components for a bayed modular enclosure containing multiple VFDs (480V/350A/321Hp each) for a dynamometer. I am concerned given...
1,723
We have a servomotor with gearbox (i=+-20) driving a big steel disc. This disc has a high inertia. Are there mechanical compensation methods for...
1,711
Hey, I am working on a project that is a bit more involved than past ones I have done. It will be using a CompactLogix PLC, and I'm using Studio...
20
5,940
I have an application where I need to reduce the travel of an actuator and also double the force. How can you do that manually, without the help...
2,488
Hi guys, Wondering if I can have your honest (and brutal) feedback on a PDF guide I'm creating for my customers. The intent of it is to help...
2,508
