I have been trying to find out if there are any redundant ethernet possibilities with a single PLC and 2 ethernet connections. The idea is that the 2 connections share the same IP/network. Currently i only know of 1 solution which is using a PLC-400 with CP-443 and use a media converter on the AUI port.
I am wondering if there are any other solutions for the PLC-300, PLC-400 series. Just adding a CP to the rack is not enough, because as i understand it this will require a new unique IP address...
Thanks for your help
Jos
Jos
