Redundant RX3i Modifying Transfer Lists Online
yorkiiii
Jun 2023
Alaska
Hey all,
I have been trying to update the transfer lists on a pair of redundant CPE330s that are currently out running in the field. According to the manual you can add hardware and modify the transfer lists online with redundant CPE330s. I can get the hardware to update with no downtime but when I try and modify the transfer lists using RMS (following PACSystems RX3i Hot Standby CPU Redundancy User Manual GFK-2308 page 65) I get the following error: [FONT=&quot] Error 8097: Controller Error – The requested action is not allowed on a target that is synchronized to another controller or the status of the remote controller prevents the requested action. [0x05][0x3D] [0x804E0031]. [/FONT]This happens after I have successfully done the RMS on the primary and then try to do the same on the secondary. Any help would be greatly appreciated as I currently have some upset operators as we cannot add new IO without downtime (even though it is advertised by Emerson that we should be able to).
Thanks!
[FONT=&quot][/FONT]
Hi, please check that you configured transfer list (CPU configuration).
Any tags with attribute "transfer list" must have address from that range.
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
285
Ive been on this job for about a year now and just got handed 2 WWTPs with RX3i cpus in redundancy. No redundant IO. Yeah, i know doesnt make...
2,242
Hey there! I was wondering if there is anyone with RX3i knowledge. I'm trying to build an architecture with several RX3i I/O nodes on the...
5,902
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
128
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
96
