Reference Archestra Tag within InTouch
Ones_Zeros
Feb 2014
at work
367
Hey
I have some field attributes created in a system platform
Environment.
I need to read these tags from an InTouch Computer
I need to create a access name to read these tags from
The computer I have the application deployed to.
Example:
Computer A = system platform computer
Computer B = InTouch computer
Setup access name on computer B to read tags from computer A
What is the correct way to configure the access name on computer B?
should be simple, but cant get it to work.
How do I configured the access name on a InTouch computer to read the field attribute from a System Platform Galaxy Node?
Here is what I have so far:
Node Name= IP Address of computer (I have also tried the computer name)
Application Name= DASABCIP
Topic Name = Name of the Device Group
Note: The DAServer lives on the remote node computer, so I have configured my tag to "Use Tagname as Item Name"
I have never tried reading a tag from a galaxy node into a Intouch computer,
so this is a little different for me
Thanks again
hope i explained it a little better
Hi Guys; I am getting this error when I try to reference anything in my template with a different reference then the name of the IO attribute...
2,702
Using: Wonderware System Plataform 3.0 SP2; Intouch 10 SP2. I used the Archestra to create objects using a script to automatically assign object...
8,247
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
418
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
301
Hey, I'm trying to do the following, I have some experience with Citect but can't seem to figure this out. I/O Tag: BoxPos1_ProdNum (Data Type...
607
