Reformat Simatic MMC card
hbojan
Apr 2006
sezana
It is possible reformatied MMC Simatic card with PLC or software and card reader.
Has anybody an idea where I can get a PC-program to format the MMC Card again in the Siemens original format?
Thanks for your answers
Bojan
So hbojan, they had you fooled too?
Some MF (#!~§!) also told me to go ahead, put the MMC into a card reader and whipe it. As you can see the contact layout is slightly different from a genuine MMC card. Sorry to disappoint you, but as to my knowledge the card is gone! I've also been snooping around for formatting software, but no luck at all. Back then I got away with it by telling the customer the card was busted.
The only thing left to do is to send it back to Siemens to get it reformatted. By now, Siemens must have an entire division doing just that. For some reason, programmers with not so nice intentions, keep harrassing PLC newcomers by telling them ******* like whiping MMC's on a laptop.
Thanks krk!
So to get the formatted MMC back on track, you will need another (working!) MMC card of the same size, make an image of it and copy this image to the faulty MMC.
Too bad I wasn't hooked up to PLCS.net back in 2004...(sigh!)
I've wiped a couple of MMC's using a card reader, and re-used them to take HMI backups (OP77 and OP277). Have never had a problem.
The problem I have got s a new OP277, which is supposed to accept both MMC and SD. Can't get it to recognise the SD. Message just comes up saying no card detected.
I have a rslogix 500 installed using factory talk activation. My laptop has been acting strange lately so I want to reformat my harddrive, but I...
7,579
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
75
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
101
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
179
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
314
