Torfinn
i have made a PLC programing for a CO2 cooling system,
i just cant get the valves for the gas cooler to work right.
first of im using a M340 Schneider electric PLC,
everything else on the system is working as it should,
there are 2 condensers for cooling the CO2 gas and there is one
regulating valve on each condenser,
these valves are have valve drivers which i send a 0-10v signal to
the problem is that when i make any change in the 0-10v signal to these drivers it takes 1-2 seconds until the driver starts moving the valves to the corresponding position.
the valve types are CCMT-24
the drivers are superheat controler EKE 1A
these are from Danfoss.
currently i have PID controllers in the PLC programming for these Valves.
this 1-2 second "delay in reaction time" from the drivers is to long, the pressure increases very quickly and we hit the safety limit for the machine which is set at 105bar the pressure setpoint is 90 bar.
pls any help is welcome and any further questions are also welcome
than you in advance
than you in advance
