Reinforcement Cage making
yxannes
Aug 2005
Singapore
38
I'm sorry this may not be directly related to PLC but can anyone recommend someone that makes good cagemakers? (Preferably auto-weld too)
Simple, just feed the machine with steel bars and then coil around them here's an example:
link
But this company needs someone to do the welding part. hopefully I can find one that is fully auto.
I have just finished the automation of a machine that makes those style of cages but up to 1500mm diameters, with formed collars if required.
The welding is automatic (up to 3 welds a second)
The machine was built as a one off by a machinery workshop for a concrete pipe manufacturer.
There are machines out of Germany and Italy (the italian ones are a poor rip off of the German designed machine) but these will cost you nearly $1,000,000US.
Personally I think the machine I saw built is a hell of a lot better than the imported ones.
Regards Alan Case
This is slightly OT, but I figure it's something we deal with when building control panels. Does anyone know of a top-entry, spring-clamp...
4,235
I'm preparing to run several large 10,000 CFM squirrel cage style blowers, each with its own VFD, and I am concerned about the regenerative...
2,871
im controling a lenze inverter using an s7 314-dp connected to it through profibus i have the application where im goin to gear this motor to a...
2,343
im a lil confused about the difference between servo motor and ac squirell cage induction motor. they both have encoders.and i i saw applications...
6,982
Have not given up on quest for 3 phase drive on electric vehicle. Have another thread "electric vehicle" Have a vendor for the controller...
20
4,361
