Hello,
I am looking for a solution to remotely access any kind of device securely across the internet. I know this has been done in piecemeal fashion since the days of dialup and I am not a total stranger to this kind of thing myself, but I have never come across one device that covers all the bases. I have used Proxicast Pocket Ports and E W O N devices to establish remote Ethernet connection but that does not help if a serial connection is waiting on the other end. I have used Moxa serial servers to make a serial connection over LAN but that doesn't help if you can't access the LAN. I have used KVM over IP devices and some of them have USB ports, but I'm not trying to look at remote video displays. Some of my jobs involve a laptop on the other end that I can access via TeamViewer or RealVNC, but doling out laptops gets expensive and/or counting on 3rd parties to have the needed software on a laptop that hasn't been crippled by their IT department is hit-or-miss.
To boil it down, I need some sort of magic box (or magic method) having all or most of the ports used for industrial comms, anywhere it's located, replicate its ports in a way that is accessible to my laptop as if those ports were physical ports on my laptop. It needs to work with VMware Workstation the same way that the ports on my laptop do. Serial, USB, ethernet, all of the things, and preferably more than one of each. Use cases:
- Someone plugs a Siemens Profibus/MPI adapter into the magic Box's USB port and my laptop detects a new USB device connected. I can access that Profibus adapter from a Siemens VM running on my laptop, and go online with a Siemens PLC 500 miles away.
- Someone connects an ethernet cable between the magic box and the isolated LAN of a Rockwell-based production line with an IP scheme like "10.10.100.xxx," and if I set the IP address of network adapter in my Rockwell VM, I can go online with any PLC, VFD, HMI, or other device on that LAN.
- Someone connects the RS485 port of a Toshiba soft starter to the box's RS485 port, a USB cable between a Click PLC and the box's USB port, and an RS232 cable from a EA9 HMI to the device's RS232 port. Now I can go online with all 3 devices and map MODBUS addresses between the PLC and soft starter and add displays for that data to the HMI. (from 1000 miles away, and using software in two different VMs)
It would be cool if the magic box had the option to access the internet over the LTE network but I assume that WiFi and/or Ethernet solutions are probably the best I can hope for (if I can hope for anything along these lines). If all else fails I could roll my own with a VPN switch in a box with various USB and serial device servers, but I would rather have a simple (looking) single device that requires zero (ok, minimal, realistically) setup from whoever might be on the other end, apart from plugging the thing in. Absolutely zero "Ok now I need you to connect a laptop to it, go into its web UI, and change this to that so that I can access it." Something that George from accounting wouldn't take one look at and throw his hands up, saying "Man I don't know anything about this electronical stuff."
Any recommendations?
