Remote operation
Jcooli09
Jul 2013
Cleveland
48
My company has come out with very strict quarantine policies to mitigate the risk of the coronavirus. Many of our terminals have only a manager and operator on site, so a quarantine will completely kill the facility.
In order to avoid this we are considering remote loading. This is pretty easy at the PLC controlled terminals, but I have 2 facilities which still use physical buttons and large relay panels.
To get around this, I've been considering using remote I/O controlled by one of the processorts at another facility. I would just rig the outputs in parallel with the buttons and switches, and connect the indicators to the inputs. I could create an HMI which looks exactly like the control board and the we could load trucks.
Another option would be to install a MicroLogix with a little IO and do the same thing, but the control would be local.
I'm looking for opinions about this, and maybe options for less expensive processors and HMI software. My company uses Rockwell/AB exclusively, but in this case I could get away with something different if it's cheaper, easier, or quicker to get, provided we don't sacrifice reliability too much.
Any opinions will be welcomed, I know some of you guys are gurus and I'm hoping you'll critique the idea.
I'd go for local control over a remote PLC. In my experience, general IO protocols and VPNs don't work very well together, unless you're using an RTU specifically designed for it. You could still have the HMI at a remote facility if you wanted.
By remote terminal do you mean that they are on the same property distance apart and you can just walk from the main operator station to the loading station or are they miles away ?
It is all doable. I would consider a small plc at each relay panel networked together just having remote IO I think would be dangerous what is going to happen if communication is lost there need to b some processing at the local site
Consider a micro 800 plc small cheap and supports communications
This would be an interesting project to do there are many ways to set it up.
I do have to wonder about the logic of trying to change this at this point. With only two people at a facility you can't get much better social distancing than that. They will likely have close contact with more people at home. I'm assuming you would restrict the drivers of trucks from your workers.
This seems more like a problem with an inflexible policy than a technical issue.
Just pulled my first AB Powerflex 525 Drive out of the box and set up the IP address using Connected Components Workbench. My goal is to be able...
4,685
Is there some way to remotely Start/Stop and Load/Unload an Ingersoll Rand compressor equipped with an Intellisys Controller ? I am trying to...
7,070
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
240
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
286
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
92
