plcplcplc1
Hello,
I'm using a 1769-L33ER, Panel View Plus 7 and a Cradlepoint router COR IBR900 Series.
All 3 devices are in the same local network. Right now I'm trying to configure the port forwarding in the router/gateway. The device is asking for the Internet Port(s), a Local Computer (IP address), Local Port(s) and the Protocol type.
Correct me if I'm wrong:
-The local computer should be the PLC I'm trying to access (I should specified the IP address)
-The Local Port(s) should be 44818 for incoming CIP communications???
-Protocol should be TCP&UDP??
-What Internet Port(s) do I need to use??
Thank you!
Thank you!
