Remote programming 5/04 with Pass-Thru
CHIP
Oct 2006
Mexico
Hello, it's posible to program a remote 5/04 cpu with the pass-thru metod?
This is my situation:
I have a running AB PLC with a 5/04 CPU, but I can't stablish communications with the RS-232 port (bad or disabled port, I don't know). So I create a pass-thru network with another 5/04 cpu like this:
I know the DH+ network is working (the green DH+ led is on and steady in both CPUs), and I can see the "Local" and "Remote" CPUs in RS-Linx, but when I try to get online with the "Remote" CPU, I get the message "DiagnosticStatus failed: 0x10". I can get online with the "Local" CPU with no problems.
I also tried changing the status bits "DH-485 Pass-Thru Disabled Bit" and "Monitor DH+ Active Node Table" without luck.
Any sugestions?
The DH+ cable is about 9 ft (3 meters).
I'm using RSLinx 2.42 and RSLogix 6.3 with Windows ME.
Thanks in advance
Not sure on what you have described, but why not have a PCMK in the laptop? This would make the laptop a node on the DH+ network and you could program any node on the network.
Hi Oakley. Unfortunatly i don't hsave the PCMK card.
Anyway, i think it's posible to connect to any node of a DH+ network with the pass-thru of the 5/04 (I hope...)
I have used Mickey's document from Rockwell to perform pass-through to another PLC and it works fine. I always forget to set the DEVICE TYPE in the RSLINX DF1 driver to KF2. Pass-trough is a little slow when monitoring fast changing logic.
Thanks all for the replies.
It worked. The problem was a misconfiguration in the Passthru Links ID in the "Local" PLC. I just change this numbers and everything worked fine.
Now i can change the program to another cpu and replace it.
Does anyone have any experience of using an ***** Flexy for remote programming/maintenance of a Codesys based controller? Rather than using the...
234
It is just me, or have other noticed that theyre more comfortable programming devices that they can see, as opposed to devices they can't see? The...
2,640
I love the fact that the Click from Automation Direct is a simple low cost PLC with great Windows software. However, the embedded solution we...
4,159
Haven't had to do this before. Can anyone tell me the procedure to setup remote programming of a micrologix 1400 with RSlogix500 micro. PLC unit...
4,048
Hi I am looking into remote access for modifications/ customer support. I will not be able to VPN so am considering 3G connection with a remote...
4,588
