Remote Programming and Monitoring
Boyko
Oct 2005
26
In the Omron's manual I've read that the PLC can be programmed and monitored remotely through a modem or Controller Link network.
Can you recommend a modem (manufacturer/model) for doing that.
If cost is an issue then get a USR56K external. It works the same as any other modem.
You will have to set it up but after you've done it once you'll not need to re-learn this again.
QUOTE]
Very true Pierre,
The Westermos are not cheap, but they are industrially 'ruggedized' (is there such a word?), and galvanically isolated, so well suited for life in a control panel.
Does anyone have any experience of using an ***** Flexy for remote programming/maintenance of a Codesys based controller? Rather than using the...
238
It is just me, or have other noticed that theyre more comfortable programming devices that they can see, as opposed to devices they can't see? The...
2,645
I love the fact that the Click from Automation Direct is a simple low cost PLC with great Windows software. However, the embedded solution we...
4,166
Haven't had to do this before. Can anyone tell me the procedure to setup remote programming of a micrologix 1400 with RSlogix500 micro. PLC unit...
4,055
Hi I am looking into remote access for modifications/ customer support. I will not be able to VPN so am considering 3G connection with a remote...
4,611
