Remote programming GSM
bytehane
Mar 2009
Finland
I need somekind of remote connection for e.g. Simatic S//300. This is for temporary maintenance connection
I found specs e.g. of Maestro UR5 GSM modem.
There is Ethernet and RS-232 and also USB.
Has anyone used this? or some other corresponding device.
Is that USB- connection transparent.
I want connect my laptop to remote PLC. I want edit Simatic- program (i have USB-MPI- converter and maybe i have to place that in connection to that remote PLC, with somekind of GSM-Modem.
Also there is OP-277 Panel, which I can program with Ethernet..
I'm living in Finland, so maybe tehe is some differensies witg GSM- standards..
Any recommendations for this?
Does anyone have any experience of using an ***** Flexy for remote programming/maintenance of a Codesys based controller? Rather than using the...
234
It is just me, or have other noticed that theyre more comfortable programming devices that they can see, as opposed to devices they can't see? The...
2,642
I love the fact that the Click from Automation Direct is a simple low cost PLC with great Windows software. However, the embedded solution we...
4,163
Haven't had to do this before. Can anyone tell me the procedure to setup remote programming of a micrologix 1400 with RSlogix500 micro. PLC unit...
4,050
Hi I am looking into remote access for modifications/ customer support. I will not be able to VPN so am considering 3G connection with a remote...
4,595
