Remote Service: preference OpenVPN, IPSec
bits'bytes
May 2010
Austria
128
Hello,
we are developing a remote maintenance solution for our machines. We want to use VPN Routers which dial out (from the machine to our VPN Server).
It seems as a general decision we have to go for OpenVPN or IPSec.
How should we decide, what are the mainly reasons for each solution.
Any input welcome and thanks in advance.
br
bb
The e*w*o*n that The PLC Kid mentions are based on a version of Open VPN (the * are there because the system here deletes the name). You can also get them to contact one of your servers rather than theirs. But I don't have the knowledge on what you could do once they contacted your system.
We have about a dozen of these in the field at the moment.
http://www.teltonika.lt/en/pages/view/?id=976 (currently retailing at about £180)
We're using them for both remote access (mainly to AB Micrologix PLCs) and for data capturing (via SQL databases). They essentially initiate an openvpn connection back to our office static IP.
Hope this helps.
Rob
Hey! I am working on Archestra IDE, and I have tried to communicate the galaxy with other networked machines, but I am getting this error, could...
1,420
Hi all, Anyone has experience in how to charge for a PLC remote monitoring service? The idea is to connect to the PLC (via PLC modem, Ethernet...
3,284
Something I've never thought about before... maybe you folks have some thoughts or experience. I have a customer that uses a Weidmuller, Modbus...
30
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
72
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
53
