Remove Symbol Comments from RSLogix 500
Psymon
Jul 2004
Wisconsin
111
I'm doing a conversion from a SLC to CLX platform. When I run the SLC program through the conversion tool, it combines the address description and symbol all into the new description. Since a majority of the symbols were truncated, some of the descriptions are looking pretty convoluted.
So is there a way to just remove all the symbol comments from an RSLogix 500 program without going through them one by one?
Thanks,
Jay
Yes, open the file in RSLogix500 and delete the database, then save it with a new name (in case you need the old commented version again). This will delete the symbols and comments from the file.
Look under Tools > Database > Delete DB
Thanks Okie -
I just exported the DB to a CSV file, then deleted the column in Excel that had the symbol comments, did your Delete DB trick, and re-imported the modified CSV file and no more symbol comments.
Hi, When the HMI (KTP1200 basic) powers up, the user has to enter their credentials to log in. In the screenshot, ADMIN has already logged in...
1,004
Hi I have removed at IO card from a 1734-AENTR Point IO, from a slot in the middle, and moved the remaining cards together. Now the Point IO...
673
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
1,997
In RSLogix5000 I am attempting to create an add-on instruction called "SWAP" which simply swaps the values of two integer tags. Here is what the...
1,968
Hello all, I have a project that I need to remove so I can restore a newer version on to the machine (win7). When I use the application manager...
1,164
