There are multiple technotes that are explaining how to uninstall an AOP using /CU option
here are directions from BF21576 | Access Level TechConnect:
".. go to Command prompt, type the path of the folder (where the installer is) and MPSetup.exe and add /cu to the command.. After entering the command, the AOP installation will begin again. Continue the steps until it asks for Install or Uninstall the AOP. Select Uninstall and complete the uninstallation. The /cu command will enable the Uninstall option."
