Removing "Unknown" AOI Parameters : Studio 5K
daba
Jul 2004
uk
5,401
Faced with the task of removing a now defunct parameter from all the AOI instance calls already programmed, and discovering no way to "remove all" from all AOIs.
It is so easy to ADD a parameter, and it will filter into the AOI instructions "en-masse", but each unknown parameter has to be removed one at a time.
I suppose I could export the file to an L5K, and edit it with a word processor, but I'd still have to find each instance call, highlight the part I don't want, and delete it, but to be honest that would probably take longer to do, and is potentially prone to errors.
Does anyone know if there a way to do this ?
What version? I just did a quick test on v32, unchecked the parameter from my AOI, and all instances it was removed.
But I do recall having this issue a few years back, and I thought it left the AOI parameter as "unknown ?", similar to JSRs...
I swear I did a find/replace on the "?" with "" that took care of it.
Version 32 : You remove the parameter from the Parameters list, but you end up with the "unknown" in the AOI instruction boxes.
I did find a much quicker way - click on the unknown parameter in the instruction, then type a "1", then press ESC, and hey presto the unknown parameter disappears ! Less mouse movements needed, and now a two-hand operation, so it's faster.
I just wish they had put a shortcut key R in the right-click context menu, so you could click on the unknowns and do Alt-R or similar.
It's too late now for me to try your Search/Replace tip. I'll bear it in mind for the next time I have to remove unknowns....
Can an AOP be removed from Logix? I seem to have some version weirdness from an E&H AOP and I need to see if reinstalling the AOP will correct it.
982
I'm making a meal of this, my brain's not in gear. Also, I'm new to S7 TIA/WinCC so excuse my ignorance... See redacted pic. Pressing F7 (SAVE...
3,226
So I have a form email saying they are removing VFD support from standard TechConnect agreement and it will be an adder in the future. We have...
17
12,740
Does anyone know how to calculate the savings from now needing to run an air compressor all day? Basically I have a design that replaced 6 * 1"...
26
4,838
Hi all, I'm installing FTView Studio ME v11 on a Virtual Machine. Using VMWare Workstation running Windows 10 (latest updates). The installation...
3,362
