Replacement Modems?
Critt
Apr 2006
Ontario
153
Hello Everyone,
Just looking for a replacement to a 9300-RADM1, that will work for a 2 wire lease line application. I have a 5/03 with a 1747-KE card connected to a 9300-RADM1 to 9300-RADM1 connect to AIC + which is connected to a Micrologix 1000.
I have used this leased line modem.
http://www.multitech.com/PRODUCTS/Families/MultiModemZBA/
The only problem I found with them is that if the lease line went down after communication between the modems had been established you had to cycle the power to the modems in order to have them reestablish communication. I ended up adding logic to the PLCs to cycle the modem’s power in the event the lease line went down.
What's unique about a lease line that the 9300 won't work?
Maybe I don't know what a lease line is. What is a lease line?
Dan
151
Hi , I am trying to replace an old inverter with a new one and its giving me issues . Once the new one was installed , the S7-300 PLC started...
135
Hi Everyone, I replaced encoder 842D-60131331BXA with a new same part number. Dip switches and Preset Push button are considered. When I tested...
241
Hello, I am kinda new to automation, I had an issue with 1743-EPAC which supply's 13 IO , when we inspected it there was a short circuit...
152
A project recently went through to replace an old computer that was running Wonderware with a new computer. After a bit of work I was able to get...
465
