kamenges
This, or something very similar, is what Charly is dealing with:
http://www.bollina.it/inglese/frameitinf.htm
I would be somewhat surprized if the drive did it's own indexing. I expect there is a separate machine controller on here somewhere that is already getting a feed roll encoder input. The question is, where is that encoder? If it is piggybacked in the DC motor then getting an AC motor with the same resolution encoder would probably be helpful. In that case Charly probably doesn't want to change the drive ratio either, unless it's relatively easy to redefine the encoder counts/mm in the controller. But if the material measurement encoder is mouinted separately from the motor then we are back to DickDV's point about relative motor/drive performance.
So, Charly, where is the material measurement encoder on the system right now?
Keith
Keith
