Replacing Program on a Micrologix
sopenco
May 2008
Cochabamba
49
Okay, I'm new to MicroLogix and a little lost here. I've searched my AB references, Google and this forum and still can't find the knowledge I need.
I have an ML1400 and I simply wish to replace the program in memory with a different program written offline.
I've tried upload, going online, clearing the PLC memory, and still, it closes my offline work and goes to the blank / empty program in memory. Even when I edit THAT program, it won't allow me to save changes.
I'm connected over ethernet, RSLinx appears to be working fine, I'm using the latest versions of that and RSLogix 5000 if any of that's relevent.
As always - I'm grateful for any help / guidance I can get along the way with this...
Also, if you want to take an offline program and put it into the PLC memory, you need to download, not upload.
Download = PC to PLC
Upload = PLC to PC
Hey, sorry - I did hit the zero one too many times. I use both 5000 and 500, I honestly didn't mean to suggest that I was using 5000 to try to communicate with a ML1400. I'm using 500 with RSS files. :)
Dmroeder - thank you! That was the stupid mistake I really WAS making that was the source of all my woes. That seems so a55-backwards to me, but it is what it is I suppose. Thanks (all)!!
I believe the definitions of upload and download are derived from a concept of "more intelligent/controlling computer" and "less intelligent/slave computer".
In this case the "more intelligent" is your PC, the "less intelligent" is the PLC
Upload is "less Intelligent" -> "more intelligent"
Download is "more intelligent" -> "less intelligent"
In the case of your PC and internet servers the roles are reversed.
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
105
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
566
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,174
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,458
I have a processer that stopped functioning L32E. The only spare available is an Compact L33ER. Are these processers compatible? The IO is...
2,226
