Replacment of op 25
dmardinly
Sep 2005
athens
40
Dears.
I have a op 25 and I must replace it with new series OP270,the Problem is that I dont have the file of protool, only I have the programme on op 25 , is there any way to get the file from op 25 and turn it to op 270.
thanks
Pro Tool
If you could send me the OP25 application I may be able to convert to TP270 and send it back.
Is it a TP270 or an MP270??
Hi, Thank you Bkottaras for your offered Help, if that ok I will send you the upload file from op 25 BY SATURDAY , but also many thanks if there is any way with OP 270.
Conversion OP25 to OP270
Can You help me?
I have same problem.
Thanks in advance,
Boris
Hi dmardinly.
The bad news is that a prosave backup file (.psb) cannot be converted.
A protool project file (.pdb) can be converted.
It sounds like you have the former only.
Hi Boris.
I think you have Protool already (if I remember from a PM), so nothing is stopping you from doing the conversion yourself. Simply select File .. Convert, and select the target device (OP270-6). There will be some system messages about a few things that wont convert. These you have to tidy up manually.
I have two old Allen Bradley 1746-A10 SER A chassis networked together and one of the chassis (master) is acting up on occation. I need to...
1,892
Hi All, I HAVE to replace a bunch of DL40’s in my plant, it’s long overdue. Rockwell doesn’t seem to have a small 4 line message display similar...
2,264
We have an A/B Dataliner DL30 that has bit the dust. It was connected to a Siemens S5 Plc output card. Is there any Quick replacements I Can...
3,485
To the Mitsubishi PLC gurus out there, I have a question. We have a machine with a FX2C-128 that we are considering replacing with the "latest and...
4,356
Hi. Merry Christmas and Happy New Year to all . I have an MM3 Inverter on ProfiBUS controled by S7-400,the FAULTY MM3 replacment will be...
1,962
