Restart command for s7-400
Bobbeh
Oct 2007
London
22
Just wondering are there any blocks that can initiate a warm or cold restart on a s7-400 cpu.
I have found blocks that can call the restart on remote cpu's
SFB19 Start com_func
SFB20 Stop com_func
but I would like to be able to get a single cpu to restart itself if I set a certain bit high for example.
How about using a PLC output to control a relay feeding the CPU power supply through n/c contacts ?
Thanks thats a good suggestion.
Am I write in thinking that would be a warm restart as retentive datablocks would still have their values.
Is there anyway I could get the plc to do a cold restart. It can be done from simatic manager so I was wondering if there is another way to do it.
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
258
How to fix if appears code “$115 plc-restart running” on the screen OP17
250
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
176
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,065
What b&r cold restart does? does its erase program permanently?
650
