RF signal propogation - Telemetry system
KKSS
Dec 2003
india
Dear all
Iam onto a telemetry project, wherein RTUs should communicate through radio modems. i need to conduct a RF signal propogation study and submit a report to the customer. Can any one suggest the ways and means to conduct RF signal propogation study. Also please let me what will be contents of such report.
I've had to do those before, but I've always hired them out to someone that specializes in that kind of thing.
I had to give the guy info on the locations and equipment, with antenna heights.
The report had all sorts of technical stuff about antenna gains and stuff, but it basically just told us that our proposed setup would work as expected.
I think he had some specialized software to compile his data.
Sorry I couldn't be of much assistance, but if you're not sure what your doing, I would suggest hiring an expert.
I also subcontract this work. The report indicates the required antenna heights, signal strengths and losses from location to location, frequencies available, lat/long of each location, any interfering signals, any objects that disrupt the signal (mountains or large buildings etc.)
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
238
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
17
772
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
261
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
83
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
305
