RFID Tags
AshleyParr
Dec 2008
Midlands, UK
184
Hey guys,
Could do with your input here. I'm currently looking into a new interlock system, and was thinking about using RFID tags but haven't done a great deal with them before & hope you could help set me straight.
Here's an example of what i am trying to achieve:
When a operator connects "Pipe A" to "Connection A" I want to be able to know that its Pipe A connected. Then if the operator connects "Pipe B" to "Connection A" I also want to know that it is Pipe B connected.
We have done before with proximity switches which gave the PLC give a different binary value depending on the pipe connected. What i want to know is can i have a RFID tag on each pipe & then a RFID reader on each of the connections?
Ash
Yes, that would be a perfectly acceptable use of the RFID.
But, how many readers and how many tags may you need? They will be more difficult to program and set up than a prox' and flag system.
They will also be more expensive. So it may be a lot of trouble for a small number of units, and may be too expensive for a large number of (especially) readers.
I did a system where we had approximately 20 readers and 100 tags on a pallet line, for keeping track of what had been done to each pallet.
RT
Sounds like a great idea if you have high enough costs associated with a mis-connection to justify the expense or have several different pipes that you need to attach to a single connection point. I show it priced at about US$500 here. Wouldn't take many foul-ups to to see a decent ROI.
I saw AB's RFID line at Automation Fair last year and they have some M18 size readers that will work out to about 30mm. I'm sure other vendors have similar.
Hi guys, Just want to ask for your expert opinion. Referencing (56rf-um001_-en-p.pdf) manual for AB RFID. See attached photo. I need to get...
1,794
Good Morning , I have been brainstorming , and researching about warehouse RFID and GPS systems. We have a large storage area with storage...
1,908
Is there a standard method for using RFID tags to handle user authentication with FactoryTalk ME? I've currently got several panels using the...
4,639
I need to gather more information about Escort Memory Systems RFID Tags and Readers. I have searched for Escort Memory Systems , and I just get...
2,823
Hello, I need some assistance in some programming. I have an application where I need to read/write to some AB RFID tags. The tags have 2k...
2,627
