RIO network Errors
Kalagaraz
Dec 2011
Kentucky
24
We have an SLC5/05 PLC that has a RIO scanner card that attaches to the IO blocks on fixture and a MARIO Board inside robot cabinet.
The mario board has an indicator light that will flash red about 10-15 times a minute indicating a network data error. After a while, the status LED will start blinking green and stop communicating with the PLC. According to manual, when it's blinking green it received a RESET OUTPUTS command from PLC. To get the cell back running, I have to shut the power off to robot cabinet and turn it back on, will work again for about an hour and do the same thing again.
Is there any way to see what errors it is getting or why it keeps getting stuck on resetting outputs?
It had been a long time since I played with a MARIO board. I would call motoman. They have a couple of slick controls people. Start the conversation off with I have a network problem. That usually bypasses most of the rookie support guys and goes straight to the advanced guys.
Is this an existing system? How long has it been doing this? What changes have been made to the system?
Can you post your. RSS file? Zip it first forum rules.
PS where are you at in KY?
Does anyone have information or documentation regarding the protocol used in Rockwell's Remote IO, and how the physical layer of the network...
948
Does anybody know if there is an actual limit on the number of drives that can be connected via RIO? I think I've heard there is a theoretical...
1,447
Would it be possible to have multiple PLC's on the same DH+ RIO network. Each controlling separate IO.
2,203
We have DH+ network on 6 PLC5. We have RSView32 as a HMI. Previously we link HMI with DH+ network by 1784-KT card but we have a problem on some...
3,037
I was wondering if a 1747-SN installed in two racks containing PLCs could be used to exchange data with each other or RIO?
1,865
