Rockwell Automation- Part Numbers for the terminal block1769-IA16 , 1759-OA16 , etc.
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I have a project coming up that has a CompactLogix 1769-IA16 , and 1769-OA16’s . They don’t come with terminal blocks do they ? Where can you find those part numbers on the Rockwell website ? Having a difficult time finding those part numbers .
Thanks so much .
Some of Rockwell's I/O platforms sell the terminal bases/blocks separately so you can choose from spring-capture and screw-terminal styles.
The full-size 1756 ControlLogix I/O platform does that, as do 1794 FLEX and 1734 POINT.
But the 1769 Compact platform offers only screw terminals, and the finger-safe removable terminal block is included with each module.
You can buy replacement terminal blocks if yours are damaged or lost; the Selection Guide says the part number is 1769-RTBN18.
FWIW the 5380 CompactLogix and 5069 Compact I/O are the same.
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
116
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
459
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
940
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
725
I have a problem with time sync working in this topology. I have a plc with grandmaster clock controlling motion groups. I wanted to add kinetix...
1,126
