Rockwell Automation Product Cofig System Down?
yam785
Jul 2004
pa.
153
I am trying to use the Rockwell Product Configuration http://www.rockwellautomation.com/en/e-tools/index.html
I am trying to configure a 1762-L40BWA Micrologix 1200 with a 1762-IFOF2, to get drawings, etc. But no matter what product I select, I even tried SLC500 products, it comes up and says "not available".
As the start-up date just got moved up two weeks, I'm in crisis mode, and severely need the drawings done today.
Can someone else try the site, and see if they can acess products?
Also, is there anyway to contact Rockwell about the issue?
Thanks to all
My feeling is your code number is missing a letter
1762-IFOF2 should be 1762-IF2OF2
But in saying that I could not get a drawing at the link you gave, but then I have never used that section myself.
Gil, you are correct sir, thank you. I've tried everything, no matter what product, even a push button comes up "unavailable"
Thanks for your help.
Im also in need of a few drawings. Tried it this morning, and just now, still no luck.
The uptime on thier part config website is pretty lousy. Sometimes it's down for the whole day. I think about 1/5 of the time I try to use it, its down. I wish they had a different way to get the drawings and data sheets. Like an FTP server or something.
Thanks to all. I found someone who had the drawings I needed. If anyone needs either of these two, I have them.
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
79
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
396
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
851
Hi everyone, I'm working on a project that involves using a Keyence LR-X100 sensor in Studio 5000 V35 ladder logic to determine the object's...
677
I have a problem with time sync working in this topology. I have a plc with grandmaster clock controlling motion groups. I wanted to add kinetix...
1,047
