Rockwell Control Logics Tags
Tim Ganz
Dec 2010
Dallas, Texas
691
I am tring to learn basic programming in control logics and I have been making different kinds of tags to get the hang of it. In the example program I am following through some of the tags use a period . Like this example TIMS.High_Level but when I make a new tag and try to use a period in it the software package won't let me do it?
Tim,
Usually when you see a tag with a period it means that tag is part of some sort of structure, like part of a User Defined Type (UDT) or part of an Add On Instruction (AOI).
So for the example you have given TIMS would be a UDT or AOI and High_Level is part of that UDT or AOI,
Mark
The period is a logical seperator. If it's just a readibility issue most use underscores.
Another use for a period is before a number 0-31 to reference a certain bit from a DINT.
So I can't use a period in my tags
Not by itself, no. The period is a delimiter that indicates that the "thing" that follows the period is a "member" of what precedes it.
e.g., in one of our programs I created a data type called "position" that has 2 integers that correspond to the word and bit location in a bit array (each position in the machine has a bit to show the part status in that position, with about 70 positions). I can then create a tag describing the position of a tool, call it "Drill1Position" and its data type will be "Position". It will have 2 members, "Bit" and "Word". To use the bit address in code, I would use "Drill1Position.Bit". The part following the period ("Bit") is a member of the part preceding the period (Drill1Position).
Note that this convention can also be used to refer to an individual bit within a word. So if you have a DINT tag, call it "yourDint", and you want to check the status of bit 13, you would say "yourDint.13"
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
125
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
281
Hi everybody, not sure if anyone else has experienced this. I have been reaching out to Rockwell Techconnect this morning to try to ask a simple...
2,391
Good Evening, I'm loading a recipe into a Rockwell ControlLogix or CompactLogix CPU via Excel, this is all working fine. Is there anyway I can...
2,048
Can anyone share the hardware/software in integrating Radio-frequency identification (RFID) security on a plant floor's OEM machine HMI's? I...
2,975
