Rockwell E300 emulated as an E3, anyone?
Ken Moore
May 2004
North, West, South Carolina
3,475
Hi Gang,
We have a large installation of Rockwell E3's. Connected to Siemens PCS-7 via a Devicenet-Profibus Gateway. I'm not sure what the exact status of the E3 is, but you cannot buy new MCC's with E3's, only E300's.
We have a new MCC with E300's and I am considering using the E3 emulation, just wondering if anyone has tried it yet. If so thoughts, concerns, issues?
Using emulation I can keep the same CFC chart structure, having all FVNR motors with the same configuration is a plus also.
I ran into this a few weeks ago when a customer called and said they replaced an E3 with an E300. They had already gone through Rockwell tech support and received the suggestion to enable the E3 emulation parameter. Customer still couldn’t get it working, hence the call to me. I read up on the emulation and decided it would be easier/faster than altering PLC code to match up with E300. After enabling the E3 emulation and cycling power, the parameters came up just like E3. I think even the icon in RSNetworx switched to E3. No PLC changes were required.
Thanks. Yeah, I watched a Youtube video on it, looks pretty straight forward. Set parameter 300 to the desired E3, cycle power and there it is. You can revert back too, if needed. I do not remember the exact parameter, 305 I think.
Hello everyone. I have a bunch of e300s connected to a startix which is then going to the plc. All of them are showing their MS and NS lights...
4,519
Does anyone know about this RAE300.msi file needed for Studio 5000 to use an Ethernet module in the I/O configuration? I looked and ran the setup...
4,147
I have E300 with an IP Address of 192.168.0.102 that I want to change. My requirement is to change it to 192.168.11.112 ! Using web...
3,731
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
168
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
