Rockwell PLC - backplace bad CRC error?
mugged99
Feb 2015
MI
22
Does anyone know what could cause a bad CRC error on the chassis backplane of a Rockwell PLC? pic below
PSVrmVj
https://imgur.com/a/PSVrmVj
i cannot get to your site, but I have had this issue with the following on a slc 500 over the last 5+ years.
1. the chassis has water / trash in the backplane.
2. corrosion on the backplane.
3. corrosion on the I/o cards at the interface point, reseat several times to clean.
4. bad connection between racks on (2) 1746A10 RACKS.
5. bad connection of the plc to the rack
6. bad power supply connection.
8. bad power supply.
Yes, this is a very dirty / dusty plant and we have had seals to rot on ridged conduit hubs.
james
wow thanks a lot james. this is some excellent info. ive had these CRC errors before and after the backplane was swapped out. So i guess I'm looking for bad pins on the module cards or a bad power supply.
Thanks!
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
400
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
374
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
801
Hello Gents, I'm now tasked with implementing source control in our projects and although I have more challenges to deal with, a big one to...
1,223
Hello I am kind of new to the Rockwell world, i've mainly worked with Siemens and Schneider untill now. I am to make a HMI application running...
1,066
