Rockwell PLC Chassis - Serial Number - RS Logix
belph
Jan 2014
Prague
27
I would like to make a small discussion about ways of reading out serial number of PLC Rack in RSLogix.
I know only about one way of doing it. There is message instruction with BackplaneRead option where you can get several information out of backplane. What concerns me now is I have like 50 PLCs running in production and want to get this information without influencing code itself and create MSG instruction.
Does anyone know what are other possibilities ?
I will really appreciate every other solution.
:sick:
Cheers!
Why do you need to get the backplane serial number? Rockwell makes a tool called the system ferret. But I don't know if it records serial numbers. i didn't even know you could get the serial number of the backplane via a MSG instruction.
Thanks guys for joining this debate, it has a great usage.
For instance imagine you have similar code of plc, but you have 20 of them and they differ in minor parameters and options.
By reading chassis number you can get precise information of each PLC and create configuration routine of parameters and options .
There is possibility by message, you just need to set correct parameters of message and specify datatype for it. Rockwell has made some specification for it.
For further see attachment.
@jkerekes: thanks will try that, perhaps thats what I need
The processor has a serial number too. I think that may be readable via a GSV instruction.
but from maintaining point of view, CPU is represented as a module which can be replaced if broken. To destroy a chassis you have to make bigger effort hehe . It's already implemented this solution and for me is only important.
How can I simply get Serial number of chassis if I have all of the PLC in RSLinx, instead of going online and create two rungs and check it 40 times :] .
Playing with System ferret now, hope this will work 4 me
System Ferret worked as I wanted. Cool Tool thank you. But what concerns me next is this dialogue window. What ProcessLogix means especially there?
Does it stop running what is scanned or not ?
I mean that PLC's that I want to scan. They are running now and cannot stop operation :] . Do you think it's safe ?
ProcessLogix was a collaboration between Rockwell and Honeywell to implement a sort of DCS system. I think its long been obsolete. I think it was more of a Honeywell product than RA. I would think you would know if you had one.
Hello Guys, I am using 1769-L36ERMS PLC by Rockwell which doesn't let me MOV or COP literal text into string datatype? i very well know the...
400
Hi all. This is a very specific issue. My first time with a Modbus ProSoft. Customer setup doesn't make any sense but we're stuck with it...
375
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
802
Hello Gents, I'm now tasked with implementing source control in our projects and although I have more challenges to deal with, a big one to...
1,223
Hello I am kind of new to the Rockwell world, i've mainly worked with Siemens and Schneider untill now. I am to make a HMI application running...
1,067
