Dustin11H3
Can anyone explain the different Rockwell servo travel modes to me? I see three options under the setup: unlimited, limited, and cyclic.
I understand that unlimited is unlimited travel and the servo will continue to run it's position as far as you'll let it.
I also understand cyclic meaning you can setup the axis to rollover back to zero at a set position (say 360 degrees).
Where I'm confused is the limited mode. I don't understand what it's for nor have I figured it out through experimentation. I reach out to RA support (they didn't know and are getting back to me), Google, and RA Knowledgebase to no avail. Any insight would be appreciated.
