Rockwell vmware and lic files
cjd1965
Apr 2007
UK
1,659
Hi
My rockwell installation has gone badso i ceated a vmware pc to overcome because i need to goto site. My licences are for FT View ME and RS Logix 5000 and all are locked to my real Hard Disk
I copied them to the folder on the vm (so in both locations) but the vm hard disk serial is not matching. FT actiation tool shows the licences but if i open RS Logix it says unlicenced
Do i need to call Rockwell and get it changed to the vm hd serial or is there a workaround. I cannot seem to borrow the licences from the host
The hard disk serial is 8 digit like XXXX-XXXX
i am not trying to pirate anything here, just get a solution
You should be able to re-host your original, and re-activate them on your vm.
You could also setup your host to be an activation server and your vm a client, but I'm betting you're looking for a quick solution if you're about to get to site.
re-hosting and reactivate, or change your serial number its not actual the hard drive serial but a windows assigned soft-serial that is setup when you install windows.
It is changeable, however depending on your setup may have other consequences, for example if you have other software using that HD serial on your vmware install.
I have used VolumeID v2.0 to change my 'HD serial' in the past when in a pickle and not able to re-host, ie no network connection. Its a simple command line tool and will allow you to change your vmware to match your old HD serial.
Added a image of me doing it on one of my vms
before and after a restart
Hi I will try that tool because it is only a temporary fix..I want ra software to be on the host
Thanks guys... i ended up setting up a licence server/client for now
Cheers
I use the USB Dongle and "attach" and "detach" it to/from the VMware session. Each session has a copy of the same licence files. I find this relatively quick and easy to use.
G.
I have a MacBook running Monterey. I have a VMWare Fusion virtual machine on it running Win10. On the VM I have the Rockwell toolkit loaded. I...
3,039
Hello Everyone, I know there are a couple of threads on VMWare and Rockwell, and it has been discussed before, but I was hoping someone could...
1,873
I am trying to get my FT activation manager on a VM using VMware to see my toolkit activations on the host machine. I am having no luck. When i...
2,652
Hi I have set up a new laptop with a high speed SSD Win 7 SP1 64bit host with a Win XP SP3 virtual operating system through VMware V10. The...
11,583
Hi new to this blog and need some advise as Rockwell have not been helpful..... New laptop with Win 7 Pro 64bit with both wired and wireless...
12,824
