VMWare Workstation Pro + Rockwell Logix FT View
celichi
Apr 2008
Greater Toronto Area
415
Hello Everyone,
I know there are a couple of threads on VMWare and Rockwell, and it has been discussed before, but I was hoping someone could explain a couple of things to me that I do not understand.
I am using Windows 10 Pro on both Host and Guest.
I am using VMWare Workstation Pro 15.5.7
In my Rockwell Guest, that I use for FT View and Logix, I have 2 Virtual Network adapters.
0 - Internet - DHCP - Internet, for activation and updates etc
1 - PLC/HMI - STATIC IP - Connection to PLC, HMIs etc
Both are bridged in the virtual network editor to a physical network adapter, both hardwired.
For the STATIC IP addressing, I offset the Virtual and Physical adapters by 1 ip address, for example...
Host (Physical Adapter) - 192.168.53.40
Guest (Virtual Adapter) - 192.168.53.41
For the Internet, both the Physical Adapter on the HOST and the Virtual adapter on the guest are configured for DHCP.
I do not have any issues with the above setup getting to PLC and HMIs. Transfer to the HMI is under 30 seconds. The internet works great on the Guest, very fast speed tests and pings 8.8.8.8 no problems.
For a reason unknown to me, this setup works on some computers, but not all. When I try to replicate the above settings on a laptop, exactly, the DHCP Internet adapter does not always get an IP address via DHCP. I have spent hours on this and I am officially stumped as to why one computer passes the DHCP request on a Bridged connection while others, there is no valid IP address configured on the Guest. Even after multiple reboots and restarts.
I am wondering if this is firewall related?
I have tried using a mixture of NAT (for internet) and Bridged (for PLC and HMI), and everything works, except the Transfer Utility to a PanelView plus takes >30 minutes, usually it is under 30 seconds.
Any insights would be greatly appreciated.
Best regards,
Paul
IN the guest's configuration, consider changing the emulated NIC from the default e1000 or e1000e to VMWare's native vmxnet3 network driver. You have to power down and close out of workstation and use notepad to edit the .vmx (INI) file
https://communities.vmware.com/t5/V...he-option-to-change-adapter-type/td-p/1396231
Thank you very much for your time.
I think it may have something to do using Wireless and connecting to certain AP related to DOS security, but I am still digging.
I am using W10 on both host and guest.
Virtual NICs are Intel 82574L on one PC that is working, I will have to check the other that is not working when that employee arrives at work.
Thanks again exabmorgan!
Hey guys, Just wondering what version of VMware Workstation everyone here is using? We are using the licensed version of VMware Workstation 10...
3,112
Hi guys, I am trying to use VMware workstation 16 player to configure RSlinx but have run in to all sorts of issues. 1. Not able to configure...
2,559
I'm currently trying to setup a VMWare Workstation VM for Rockwell PLC's I would like to have RSLogix 5 v10, RSLogix 500 v12, RSLogix 5000...
3,391
Hello Fellow Techies, I was wondering if anyone had a good setup from Host to Guest wrt network configuration. When I use the ME Transfer, it...
1,011
Hi, This is new to me - I used to connect Rockwell software thru Ethernet cables, now we got a router attached to the PLC. Having hard time to...
3,377
