Rotary knife control
I agree with the assessment that you are getting about as much performance as you can expect out of your PLC. Consider this: At 80 meters/minute, the web is traveling at 1.3 mm/millisecond. If your PLC scan time is 10 milliseconds, the web is moving 13.33 mm each PLC scan. Once per scan is the fastest you can update any commands the PLC sends to the drive. That's why you need a dedicated motion controller.
Does your system simply try to maintain the knife speed at a ratio to the web speed or do you vary the ratio so as to match the blade speed to the web speed while the knife makes the cut? If the latter, is the knife motor large enough to provide the torque required to accelerate the knife cylinder at the higher web speed?
Got the same results you did. Also when you take into account that the scan is not synchronized with your process a more accurate expected error would be +/- 26.66 mm.
Attached is a sketch of our latest project, it's a retro fit of a Hudson Sharp bag machine. It's basically a rotary knife (perforator) in this...
25
8,377
Hey everyone. Im doing rotary knife application for my senior design project. I need some help about the program. i dont understand some parts...
1,854
Hi.. I have flying shear application using rotary knife. The line speed is 100 FPM and rotary knife using Vector motor with Inverter for speed...
6,461
Hi All, I have a rotary cut-to-length knife application and I am using an AB 1394 drive. Board Speed range 40 to 90fpm. Cut length 8 to 16ft. A...
9,452
M
I,m looking for a controller for a rotary knife, similar to the contrex m-rotary, but with better interfacing capability(such as modbus). The...
4,348
