These are off in left field, well maybe even several paddocks over from left field.
I put this search term into Google "motor slip measurment"
and these 3 exerps caught my eye on the first 2 pages
http://www.patentstorm.us/patents/6042265-description.html
Most motor installations are not equipped with speed sensors so a direct measurement of the speed/slip is not possible. However signals appear in the current that may be used to estimate speed quite precisely. Virtually all motors have some degree of rotor asymmetry, which results in the appearance of frequencies in the motor current related to the slip. The most prominent of these is found at two slip frequencies below the line frequency and its magnitude is often used as a measure of the severity and number of broken rotor bars. Examination of this spectrum, which may be automated, therefore yields the required slip frequency.
http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel5/7381/20066/00928884.pdf
An induction motor speed measurement based on current harmonic analysis with Chirp-Z Transform
Aiello, M.; Cataliotti, A.; Nuccio, S.
Instrumentation and Measurement Technology Conference, 2001. IMTC 2001. Proceedings of the 18th IEEE
Volume 1, Issue , 21-23 May 2001 Page(s):578 - 582 vol.1
Digital Object Identifier 10.1109/IMTC.2001.928884
Summary:The paper presents a new method to measure motor speed by means of frequency estimation of rotor slot harmonics present in the supply current of squirrel single cage induction motors. The novelty of the method is the use of Chirp-Z Transform as supply current harmonic analysis. The advantages are an improved spectral resolution and accuracy. Moreover a shorter sampling time window is required reducing errors related to not stationary current signal. Experimental results are presented to validate the proposed method and to perform a comparison with FFT based one
http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel5/7381/20096/00929542.pdfNon-invasive slip measurement of induction motors
Micheletti, R.; Pieri, R.
Volume 3, Issue , 2001 Page(s):1958 - 1961 vol.3
Digital Object Identifier 10.1109/IMTC.2001.929542
Summary:The paper deals with the accurate slip measurement of induction motors. The proposed procedure uses a non-invasive slip measurement scheme based on digital filtering and dynamic parameter estimation. The slip measurement is carried out without a speed sensor and is deduced utilizing the magnetic field in proximity of the induction motor. First the waveform of the induced e.m.f., taken from a search coil, is filtered using algorithms based on the discrete Fourier transform. Then the stator frequency and rotor frequency are obtained by comparing the filtered voltage with a mathematical model using an optimization procedure. The model's parameters are varied until an adequate match is obtained with the filtered voltage. Experimental results are presented to validate this method
