Setpoint in FPM on Panel and drive Powerflex 755T in RPM of Hz
Frederik8484
May 2020
Limburg
Dear
We are working in AB Studio 5000 and the drive is a PowerFlex 755T. For this project I need to control a conveyor to a certain set point. This set point is entered on a panel with the unit Feet/Minute (FPM). The drive can be controlled in RPM (0-1500 rpm) or in Hz (0 - 60Hz). The formula to convert FPM to RPM is RPM=(FPM∗12)/(π∗Diameter). To read the feedback from the drive, I need to convert the RPM to FPM to visualize on the panel (FPM= RPM* Diameter * π). Is there an easier way to do this or am I required to work with these formulas?
I hope someone can help me further.
Thank you in advance.
Kind regards,
Frederik
I wouldn't worry about circumference and diameter calculations. Just use a single multiplier and a hand held tach. Enter your desired FPM and tach the belt. Multiply the FPM by a coefficient that gives the correct RPM to the drive until your tach matches your SP. Use the same final value to go the other way for the feedback.
I've asked this before but I still couldn't make it work. I just can't envision a solution. Local RTU has a screen to set a handful of...
18
1,563
Hello, I use a Siemens Sinamics G120C inverter in combination with a S7-1200 cpu. I use the Main Setpoint with the Providrive option and send...
731
Hi All, I'm using Studio 5000 ver 30 to modify existing logic that has PID, and I want to be able to use an external/remote source as a setpoint...
637
Im using the built-in PIDE faceplate in Studio View ME connected to a PIDE in Logix Designer and having trouble getting the faceplate to allow the...
1,500
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,077
