Gil47
When sprocket is rotating,
Can you measure a voltage from signal to com with a multimeter,
Next if the multimeter measures Hz are you seeing something close to 3000Hz.
3000Hz is a fairly fast rate when you need to consider on and off times of the pulse rate.
You say its well within specs, but they always quote fastest, under perfect conditions.
