RS-232 cable connection for PLC and microcontroller
chintan12
Mar 2013
delhi
HELLO FRIENDS
i am very new to serial communication so i want to ask a basic question
i am communicating MICROLOGIX PLC(which have DB-9 serial port) with micro controller serially and as i know that microcontroller have TTL level signals
i have bought a RS-232 to TTL Converter
now my question is which cable i should use for connecting PLC to RS-232 to TTL Converter??
will it be a straight or cross cable??
please also tell me the connection
thank you so much in advance
Since you said the MicroLogix has a DB9 style port, you do not need the A-B cable, which has a round mini-DIN8 connector.
Use any general purpose "null modem" cable, or a straight-through cable with a null modem adapter.
thank you so much to all for intrest in my post
i will make my own null modem cable and try
still i have little doubt
my friend just told me that no need to do soldering of whole null cable
just 3 connections which i described bellow will work
PLC(db-9) CONVERTOR (db-9)
2 ----------------------- 3
3 ----------------------- 2
5 ----------------------- 5
is it correct????
i have ML-1400 CPU
and as i know that microcontroller have ttl level output so i am puuting a RS-232 to TTL Converter in between
Hi All, I have a SLC 5/04 plc that I need to communicate to - however we don't have any null modem rs232 cables on site. I am very new to Allen...
2,667
Hello everyone, How important is it to obtain cable pinouts from a vendor whem connecting a device with DB9 connector to a device with DB25...
2,657
We have a third-party rs232 cable, can we connect it to the Rockwell PLC-5/30 and upload the program ? The controller is an Allen Bradley 1785-L30B .
4,039
For connecting to a Micrologix through a 1761-NET-AIC, the manual specifies that you should use "RS 232 Communication Cables Cable, Cat. No...
1,377
dear all: i need schematic for connecting pc to pacdrive mc4 .please share it and i need software for that .psa4 software and activation code.
25
12,616
